So far, it's a cool idea. Seems to hold everything in alignment. The only thing I noticed with mine is they are slightly warped. So to make sure all fuse supports were in place solidly I simply put a heavy weight right in the middle of the jig. It's ok for now but suspect I'll have to do something else when it comes time to frame the wings. The only construction I have found so far on the Pitts that is not perfect, is the leading edge of the fin. Not the jigs fault on this. Those pieces were slightly warped when removed from the box. I'll just have to saturated with water before finishing the construction on it and pay particular attention to insure a straight fin.What's your thoughts on the jigs supplied with the kit?
Al
. My AMR Stick is the first plane I've built using a jig. It has a jig for building the wing halves and I love it. . . . .
