Good morning Rusty,
1. How's the balance on two of them: right now (on the red/blue/white one), with no pilot in there, If I raise the airplane by the wing tube, it is slightly nose heavy. meaning, a split second after lifting it from wing tube, nose slowly drops. (no wings on, canopy on).
the orange and white one, has no radio in it, no rudder servos installed, no batteries, but If I pick it up, same location, the tail drops, well, tail stays down.
2. will you use the 5.5oz or 1.5 oz pilot in the blue and red bird ? I am probably going to need a heavier pilot on that one.
3. Like how you fastened the baffle and shroud down , doubt the bolts will loosen . Thank you, it took a good while to do that step, but now it is done!
4. I have to order a few Mcfuelers as well they just look sharp on the cowl . I really like them, they are durable, and I have never had one come loose.
