Have a question to you gentleman. Building a Sportster 60 and just about to build the wing. The wing has 2.5 degrees of dihedral per wing panel or 5 degrees total wing tip to wing tip. Has anyone built this plane and removed the dihedral and built it as flat wing. If so what was out come and did you like it. I built a AstrHog once and removed the dihedral and it was not good. The plane flew great everything was fine until you applied the rudder in the air the plane would turn in the opposite direction to the rudder input. Thanks for your help.
