Buddy5303
Initially, I see two problem areas. Block off the back of the motor. Also the front of the engine. Air as you know, is like water. It will always follow the path of least resistance. The air has to be forced down through all four cylinders. To do this, you need to block off any where the air can escape before making it to the jugs. A split cowl like my son's big Edge is pretty easy to do. But as you can see with the Yaks one peice round cowl, I had to build around the dub and build a full box that is completely closed off. The air will be forced down through the cylinders. Then with the louvers on the cowl, the 4"×5" open in the bottom of the cowl where the front dumps...dump and the belly vent to allow air to pass out over the cans...there is plenty of positive "pull" to help the air to be drawn out. I will try to get photos of Shayne's P.U., I mean P.A.U. 43% Edge.
Thanks for the pointers. I will block the back off and finish the baffles around the front of the engine. The front of the cowl is blocked off on the bottom just two little square holes to let air in. I will post some pictures tonight of that. I would still like to see the pictures of the edge if you don't mind.
