tylerzx9r
That is a good hint/ trick, I will get another Iron just for that purpose!I find that a cool temp setting... heat that will tack down an over lay gently enable some rework and some wood pecker prep to be the key. Two irons are critical. Cool iron tack and position to lay flat, then the second hotter iron to finalize the placement. NO RUBBING. You are not ironing a shirt. Place heat and move on. Resist sliding contact.
I F love to cover. You see your plane develop in front of you!
