For Sale Post your extra spinners for sale here!
Bartman
Defender of the Noob!
Hey folks!
Got a few extra spinners? Need a spinner? Use this thread to put them up for sale.
The spinner below is no longer available.
I've got a 4" aluminum spinner, it has a part# stamped inside the cone and I was able to locate it online (mine is an AW72 with the solid backplate which is different from the lightened backplate in the link below)
http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=593
So it's an Airwild Nova, Extra style 4" 2-blade, here are a couple of pics, i used a steel insert to make it fit the engine that I had it on but the actual hole is drilled to 1/2". I can pop the insert out and use drill bits to get a more accurate bore dimension for you if you'd like.
I'm looking for a 3", 2 blade spinner. aluminum, red, or white, normal style.
Also looking for a 3.5" Extra style like the one above for a 2 blade prop, DA50
kork
Bart, is the 4" a ultimate? I am looking for one
how bout a picture?
Still looking,,,,
Hey folks!
I've got a 4" aluminum spinner, 2 blade, forget the brand but it's pretty heavy duty, solid backplate. I'll post a picture later tonight. Looking for a 3", 2 blade spinner. aluminum, red, or white, normal style.
Bart,
I have a Tru-Turn 3" painted Apple red. It is sloted for 120-180 (20cc-30cc) size props and I actually had a Falcon 20x8 being used with it. It has a solid backplate.
thurmma
Spinner is sold. @Bartman you can delete this post :)
Bartman
how bout a picture?
Kork,
First post was updated with the info on the 4" spinner that I have available.
I didn't subscribe to the thread when I posted it so I apologize for not being through here in a few days.
Bart
I got a couple of spinners. Will update the ad when I get home.
4.5" TruTurn 2 blade, drilled 100cc. 5" GraphTech 2 blade carbon fiber, drilled 150cc. Both need cleaned up.
4.5" spinner $65 shipped.
5" GraphTech $50 shipped.
Can get pics.
Also found a 4.5" GraphTech CF spinner. Same price as the 5". These spinners are the 3 from L to R.
kork
Kork,
Bart
Sorry Bart but I am looking for one with the stock center hole. I am looking to install on a 60
ExtraNuts
I have 3-4 Tru-turn 2 blade 3.5 ultimate style spinners and a couple other non ultimate's that are slight smaller.
