Fibertech
I had pulled the stab from the vacuum bag earlier in the week and add the LE and TE stock. I planed the edges off and did some light sanding. Next I marked out the hinge line and did some cutting. From another build I had some left over balsa hinge stock already cut so I marked out the center line and glued up to stab and then squared it up to fuse.
I used gorilla poly glue for the LE & TE and also on the bottom of the stab that gets fixed to stab ply plate. The balsa hinge stock was also glue to stab with poly glue bit I used the Gorilla wood glue for the balsa to ply areas and lots of tape.
