@bigblueswope I neglected to mention the servo in the head is on a separate channel, mixed with the rudder, and is reversible. When I make a low close in Knife edge pass he is looking out the side.Flip a switch and he can clear the airspace to the right and left when taxiing out to the runway after getting clearance from the tower LOL!!! As to how I designed it. The servo is in the head mounted upside down and the horn is glued in the shoulder portion of the figure. Because of the vibration, and ease of repair you can remove the head with the horn mounting screw install a new mini servo. and put him back together. There is a lite plywood plate glued to the bottom of the figure and mounted with four small wood screws, to remove the Figure if repair is needed, and a small hole in the canopy floor for the servo wire. :way_to_go:
That my friend is f'ing AWESOME!
HornetNZ
Finished 2 new foamies for NEF. WMPF Mcfoamy X (Depron) and WMPF Vengeance. :)
Just ordered my floor tiles for the shop! Won't be these quite these colors and design, but it is snap together tiles with diamond plate top.
I've been checking these out as well. If we sell / buy a new house I'm slightly optimistic for an unfinished basement so I can build a man cave and put these on the floor. Where did you get yours?
Been thinking of a way to use the wasted space in the topper of the truck when traveling to events. Back when I flew glow and took 5 or so planes to the field every time out I made a platform. After talking with @Pete Rosas he gave me the idea that I think will work great. He's a metal guy though so I had to CNC mine out of plywood. It will be plywood and birch solid wood frame with a thin plywood platform. Will work perfectly for wing bags and small things. Ended up being a 55 x 65 x 9.5" space after I got it assembled and test fit. Need to wrap up the plywood and upper rails and I'll get it installed this weekend.
ChickenBalls
"Cool Guy"
Did I mention how beautiful NC is, especially the Sandhill's area. Nall is only bout 3hr drive. Chickenballs or his son (once he gets older) would mow your grass for FREE. I'd go as far as to throw in one of my Pit Bitches, if we could get ya'll to move here.
Alpha20
Finished a depron model (Click 3D Evo), and then installed aileron servos in my new compy Extra. I can hardly get in and out of my hobbyroom which is only 3X3 meters..
