3D Viper build log (maybe)
That's a tricky question. Are you experienced with the proper way to use a DA sander? And, what type are you talking about, air or electric?
For those of us in the wood working industry (especially those of us that have had employees) will tell you that the hand held sander is the most dangerous tool in the ship with regards to being able to take a beautiful piece of work and turn it into trash in a matter of minute.
I've been using air sanders for 30+ years now so I understand how to hold and control one and yes I use DA sanders even for sheeted wings. I also have three different sanders with three different orbits and grits for best control.
If you say you are going to use an electric DA sander I would tell you HELL NO!!! You simply can't control the weight of that tool, and the sanding action with any degree of accuracy when doing something delicate like balsa or lite ply.
Got it. By hand it is.
PS - you don't want to sand on anything on the fuse until you have the turtle deck, belly pan and canopy deck assembled and installed, so resist the temptation to perdy it up with a sander.
I do typically give a light sanding to remove the laser flare before assembly of the parts though.
daman691003
My god it was scary. I glued in the floor and it was scary. I used wood glue and I'll follow with hysol. It's a nice tight fit. I had to use about 12 clamps. It's now solid as a rock.
Yup, floor is a tricky part. Thank goodness for test fitting to play your attack:yesss:.
That part takes little stress but plays key roll in holding the entire plane in alignment. All downhill from there.
daman691003
Pics
