Aeroworks with ZDZ180
Flyrcjoe
The rudder is finished and I have moved onto finishing the motor. I built the mount for the JMB canister. I took a piece of light ply and curved the back of the canister tunnel. I then filled in the side voids with 1/8 balsa. When that was all done I painted it grey with a clear coat.
Flyrcjoe
My good friend Jim came over and while we hung out he cut all of the lower air vents in the cowling for me. He did a great job, thanks!
Joe, I have had issue in the past with the covering around exhaust openings. It was always a pain to keep it down. Since I have been using this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXG853 it took away all issues.
Flyrcjoe
Used the aero works factory servo mounts and a 4 1/2 inch turn buckle so that I can get it programmed and adjusted perfect. I have been using turn buckles for some time now and really like the adjustability, resulting in a more precise programming .
AEROSHELDON
I have never seen those before. It looks like they would work but I wonder if the hinge piece would be too small? Something to look at and try though.
I have not either, but it seems like it would work.
Does the velocity stack come with the 180?
