You can get bungee cord in many diameters, my Super Cub uses 1/8" cord.  I found on the Champ that stiffer springs work better.  I had 50 pound per inch springs that just barely deflected at rest, anything less a perfect greased landing the plane bounced.  At a scale contest last year, was chatting with Mike Barbee and told me that he likes his gear stiff.  After that I added a second internal spring to each strut and my landings improved.  Photos of the Cub gear are below, on the Cub, the bungees are 36" long stretched and wrapped so there are 20 strands, Started with 26" long but too soft.
Springs are like steel balls, drop a steel ball on a hard surface and it will bounce almost to the height it was bounced just like the old Super Balls, wonder if they are still made?  Drop a regular rubber ball and it comes up to half the height it was dropped.
So what I'm thinking is a piece of 1/16 or 3/32" music wire bend to a "V" shape attached to both axles with an eyebolt attached at the bend.  Drill a hole through the center of the gear so that the eyebolt will fit through, stack rubber washers to a height of maybe 1 1/2", top with a steel washer and lock nut.  You can play with the height and static tension to get what you want.
View attachment 124069View attachment 124068
