acerc
Not even close to happening.By the way by the time you are all done Acerc is going to make a claim on the cub.
You are more than welcome to join me on this thread it’s all planes
You lucky it does not have a four stroke on it.Great! I am going to install an Aura 8 in the Cub and finish the painting then install dummy engine exhaust.
Something tells me "I don't think so"
Must say the dummy engine really does look good.Well.....Here it is all done with the exception of the scale exhaust. Currently looking for some 1/4" copper tube and fittings.
The only thing I can think off is Stits clear.Thanks Snoop's. I have an idea on why the plane has a not so good glide slope. Yes the 17 pound (wet) take off weight is not helping but this thing should still "float" like a Cub. The stits covering on the wing is painted nicely but the fabric has not been sealed. You can blow air right through it rather easily. I think air is "bleeding" through hindering "lift" under the wing. Going to see if I can find something to spray to seal up the bottom of the wing.
Check out flex seal at the local hardware store!!!!!
