Pontus and I just got finished with our run. 24x10TH Mej, Glacier 2x 6s5000 45C packs.
We warmed the motor and battery up for about 1.5 minutes, mixed throttle from low to med-high, bursts, etc.
Starting approximately 2 minutes in, we began the run:
10 sec - 117.3A, 43.1v, 5055w
20 sec - 114.2A, 42.7v, 4880w
30 sec - 113.8A, 42.5v, 4836w
Let it rest and recover for about 1 minute, then did it again:
10 sec - 122.3A, 43.3v, 5300w
20 sec - 119.8A, 42.5v, 5080w
30 sec - 115.1A, 42.2v, 4900w
RPM data was taken using hand held prop tach, and wasn't recorded.
First run peaked 6400, settled at 6250 for the remainder.
Second run peaked 6500, settled at 6340 for the remainder.
I personally don't have a ton of confidence in the little hand held RPM thing, but they're probably in the ballpark.
Also, it seems the numbers taken with the 24x9 Xion were skewed as a result of the prop being horribly out of balance. As a matter of fact, even adding a servo clip to the tip of one blade wouldn't balance it.
Hope this all helps.
Also, motor temp 3 minutes after this abuse was a comfy 141F peak, OAT 58F.
