Sport 30% Edge 540 Pete Marshall Plans with Laser Cut Short Kit
Bluepilot2003
I am currently on a work trip but was able to order the wing and stab tubes along with the landing gear and a couple other odds and ends needed. This is the weekend the build should start! Sorry for the delays... more to myself than to all of you:)
Bluepilot2003
The bottom main stringers have a 5 degree bend somewhat close to the front. I am using about a 20 degree overlap for extensions, so for the 5 degree bend in the stringer, I just cut the front piece 5 degrees closer to 90 to get the angle needed.
I found out that I need to do a bit of sanding on the tank floor and motor box top to make them fit properly.
Better to sand a little to get it to fit than it being to small. Looks good brotha and glad you finally got it under way.
Bluepilot2003
@cbarnes0061 True story. Much easier to sand to shape. Sure glad I have those handy, dandy sanding blocks!
I am going to stop and get more clips today. My stash of 6 tiny clips and 2 clips of bigger sizes isn't going to cover it!!
