Enterprise
Comparing this setup to 4325-425, you should be able to spin a 19x8 faster than that can spin the Xoar 18x10 PJN. I thought that was stupid power. If that aft battery tray is all that is needed to make this work, then this should be a very fun airplane and project. Other thing to consider is to make a tray to mount the gas tank aft of the spar. This will help with CG and make the plane more nose heavy when it is time to land. That is something you can do at the end once, you have a good idea on the CG.
