@Lost It you were right bro. Here's what they are saying is going on.
EF...
We have found a very isolated issue with the ESC having troubles withthe low voltage signal from some 24.ghz receivers.
We have worked with our factory and we have received a short extensionthat is to be plugged in between the wire from the ESC and into thethrottle channel on the RX. It is a very small, lightweight signalamplifier and should take care of the issue.
I'll get it sent right out.
Hopefully this helps others if you run into the same problem and wonder why.
