That's super coola short Video on the aileron setup
Roger....watched this a few times. Am I correct that the small boost tab servo is programmed to provide appropriate tab deflection, given the amount of aileron movement, which is actually driven by the large servo/torque tube?a short Video on the aileron setup
Your exactly right, its controlled by an extra aileron channel, which I can then adjust it properly,,,Roger....watched this a few times. Am I correct that the small boost tab servo is programmed to provide appropriate tab deflection, given the amount of aileron movement, which is actually driven by the large servo/torque tube?
Oh too cool. So no control surface trimming? Trimmed with boost tabs as well as independent fine tuning? Or does it even work that way? Never seen the boost tabs on an rc. It's just...neat!Your exactly right, its controlled by an extra aileron channel, which I can then adjust it properly,,,
You still have to trim the proper way of radio control airplanes, these boost tabs are just boost capable to help the main servo.Oh too cool. So no control surface trimming? Trimmed with boost tabs as well as independent fine tuning? Or does it even work that way? Never seen the boost tabs on an rc. It's just...neat!
That's a good question, I probably could get the amperage from the servo, I might just try that , thanks for the suggestion.Roger...will your telemetry allow you to see amperage draw on the boost tab servo? Not sure if it is possible to get the right amount of movement so it doesn't fight the main ail servo.
Thanks, yes I have but they don't have as big as 3 incheshave you tried aircraftspruce.com? i believe they sell raw metals by the foot
