60" Extra 300 EXP
m0dest
Nice flying!! Really enjoy the ripples in the water on the throttle punches while you're hovering. Great video :D
Thanks!! Going to try to get some more video when the weather lets up. The iphone only does so good a job. Need to invest in a decent camcorder. That 60" is my basically my first balsa plane. Maiden was July 4th 2012. Flew a scratch built flat foamy for a couple months before that and started with a micro Trojan T-28 I got around January I think, then I got a GP 55" Extra 300SP in February that burnt up 2 minutes into flight. Bad ESC or Motor. After waiting 3 months for warranty replacement on the ESC I did a search on 60" class 3D/Precision planes and found Extreme Flight and 3DHS and decided on EF.
Couldn't be happier. Can't believe it made it the first couple flights. I literally could not land...took a few passes to get her down. The Micro Trojan was the only other thing I had landed that had landing gears.
I'm hooked now though.
Nice, I think I saw that somewhere else. Great site. Like the frog cheering section too!
He was a noisy little guy. ;)
dth7
Well, you've certainly come a long way! Great job. Only took a few planes to find precision and 3D nervana!
rcbirk21
finally got out to maiden my 60 extra. what a great flying plane. it was a tad bit windy, but i really like it. not too comfortable with KE flight with this plane (probably because the other plane i had out was my 65 vyper which is the king of KE flight), but holy cow is this extra easy to pop into a hover
How is your CG? I found the KE to be relatively stable with a tiny bit of mixing, at right around 5mm forward of neutral.
rcbirk21
i ended up moving my 6s3300 packs about 1 or 2 inches in front of the wing tube. inverted is level, so might need to go a bit more forward. knife edge needs mixing
dth7
I'm running the 6 s 3300 s about 1/2-3/4" fwd of the tube and its pretty stable with KE and KE loops. How about the "walls" and pop tops with this thing. Really awesome airframe. Still looking for the sweet spot but I'm real close and having a blast. I practiced some IMAC with it and it really draws nice lines too. Tried without the sfgs and its nice with "naked tips" too.
rcbirk21
yeah i didnt get a chance to put the sfg's on yet. its just such a pain to transport the wings with the sfg's on
quadracer
Mine holds KE no problem, no SFG's. I am barely getting 45 degrees of rudder, too. I need to switch out the stock Hitec arm for a bit longer one. Pop tops and tumbles are kinda weak with small rudder throws.
