Ohio AV8TOR
Just Do It
What props are you guys using? I am using the same Xoar 16x7 that I use on my 60" Edge but I may try a 16x8.
Wedoital- I think 75 degrees is sufficient! Or are you trying to make speed brakes?
I know I can get 90![]()
90 acts as a brake and doesn't do much. 75 is more than enough elevator on this plane.
I would be worried about the hinges failing with 90 degrees.
do you know off hand what throws you are getting on your ailerons, elevator and rudder
Xoar (white) 16x8 on motrofly...480
plenty of vertical
