It's now officially a "free plane" so next time out I will fly it much harder
Someone asked me how it did a falling leaf, (
Very nicely, is the answer) and after the 7th or 8th flip the elevator
decided to hang full up at 75+ degrees. After the initial shock wore off, and I fought it back gently from a couple flips,
I was able to harrier it around to a not-as-hard-as-some-of-my-intentional-harrier-landings plop.
Zero damage, not even a prop.
On the ground, the servo was hard UP as commanded that way. Wasn't a linkage or other bind holding it.
Everything else normal. I wish I had thought to check my monitor on the transmitter to see what it was
commanding but simply turned it off, and the elevator immediately went to my neutral failsafe position.
Turning the radio back on, everything is perfect again.
Discharged another battery on the ground doing nothing but "full up --> full down" and never happened again.
/facepalm. Why can't stuff just
break so we know what it is?
<shrug> I turned my travel back from 150 to 140 and I'll give it another go tomorrow.
