Thank you Gary.
Need to order more for the other planes.
My pleasure. Here is the link for when you're ready: http://www.3drcforums.com/showpost.php?p=2416
Thank you Gary.
Just pulled the trigger on one of these. Unloaded from the 3dhs Australia container yesterday and now on its way to me.
Hey guys, have a few questions. First off, have any of you had to use quite a bit of washers to space a dle 30 out to clear the cowl with a spinner. I started with adding one washer between the motor and the standoffs, and wound up with 3 washers on each standoff to clear the cowl.
Also, this is more of a request, but can somebody post a picture of their throttle servo location/setup with a dle 30. I have mine mounted on it's side in the motorbox area, and it is a pain in the arse to make any adjustments to the linkage, I would like to move it to the slot in the bottom of the motorbox right behind the firewall, but not sure how to set the linkage to do this.
Any help would be greatly appreciated!
Thanks Gyro. I don't know on the spacing either. I tried with no spacers, and my spinner rubbed the cowl. I then took the spinner off thinking maybe it would help to run without and the prop rubbed on it. Put in one washer, still rubbed. Do you have any washers between the firewall and the standoffs, I see that some people run a fender washer on the front and the rear of the firewall.
Gyro, Do you have a picture that shows how you have your linkage set up on the throttle end? Using that slot in the bottom of the motorbox looks like it would be a lot more convenient than where I have mine mounted currently.
