72" Extra 330SC
Actually, it was more than that. The "neck" (I'm sure it has a name) of the crank case leading up to the prop hub was cracked. The material was very thin, so it was an accident waiting to happen. The v2 crank case is much thicker. Mike at ibcinyoyrc fixed it under warranty and upgraded it to a v2 crank case, so all is well now!
so are you saying you broke your neck?
rcbirk21
i use it. no problems in 50 flights plus bec pros on a bunch of other planes in this size never a problem knock on wood
Ahmed
Forgot to ad this picture
