I'm running 20ga... Made mine from scratch one is 47" the other is 49". I'm sure you could get away with two 48" ers. My RX is here. View attachment 32638
[MENTION=443]ghoffman[/MENTION] has the printer back up. Send him a PM.I still need a set too
This plane builds out at 21 or more pounds. DA-60 with a pipe is OK power, but not outstanding. Most do DA-70 or DA-85. One guy I doing a DLE-85 over on the FG thread.
Tony at DA steered me toward the 70 and away from the 85 for this airframe. If going that big a single you may want to beef up the airframe a bit. Especially in the motor mount. Just in case! If you think you "Need" more power check out Jase's video. He's on a 70 w mufflers no can no pipe. Dunno but looks like it has plenty pull!
https://m.youtube.com/watch?v=Ml50CMmWatY&list=FLKuCNTGzcffrySHwp62GiyA
This is a piped DA 60-
https://m.youtube.com/watch?v=62B74WkOmcs
Depending on your needs I think a piped 60/ 61 should be fine. I went with the 70 to get into a twin and have a little different throttle curve. Good luck.
