Unless you are a paid advertiser NO more posting advertisement in the individual vendor forums. You may post in the Manufacturer's Announcements section only but only ONCE a month unless your a paid advertiser.
Question, how much tension do I need in the pull pull cables.... I can't find the way to make may rudder servo be quiet.... Only when the cables are really loose the servo stops the Hummmmm
Ok so I use Savox servos on my airplanes too, they do hum a little, even with the weight of the control surface on them, it is not a bad thing. As long as the cables are not overly tight, and the servo isnt screaming, you will be fine.
Yes I change it. I'm using Common Sense on Ail and Elev, and then i put the Torq on the rudder.
Guys, I solve the problem
With the pull pull cables, I can say that i'm done with the building, now my problem is with the CG.... Plane is tail heavy (a lot).
If anything I'd say mine is turning out nose heavy. Made a tray just below and behind the rudder servo. CG is just infront of the wing tube. I've heard 1" in front of the tube.
