jhelber08
I'm guessing rich on low. Check out the low needle tuning in fist post and try that. Also make sure the little idle set screw in the carb is removed.
@jhelber08 sounds like an ignition or possible IBEC as well. What type of IBEC do you have? If you have one, I would try an ignition swap first though.
Techaero Ibec. I do have a spare twin da ignition and that is the first thing I plan to try when I get back from offshore...just didn't have time to do it as it was the morning I was leaving for work I also have a few brand new Ibecs as well since I was planning to convert all my planes over at some point.
