SwaggerJacker
49dimes: Best avatar ever! Brilliant!
@49dimes can you explane please the signal voltage. How is it checked. Is it across the signal wire and the ground wire to the servo. And what should it be. Thanks. Does it change as the radio input is changed to the servo. ?
So you trust your i10 with your giants? I may try my FlySky with my plane to see if I get better results. Wonder what the resolution is with my Graupner receivers. Time to dig up info!Speaking of compatibility..........
Finally got the 330sc to the field today after some needed shop time. During pre flight I saw the left (channel 1) aileron servo start freaking out all on its own. And to add to the enigma the rudder servo would only work intermittently.
Went over the extensions and connections and found weak pin and sockets for channel extensions. When I forcibly held the connector to its plug the aileron stopped freaking out. Noticed that the motion of travel was a bit "shaky" as I cycled the control surfaces. Felt the bottom of the rudder servo and it was getting hot.
I believe my problems lie in......1) Servo extensions have lost their grip on the pins.
2) The R6014HS receiver is 2048 resolution not 4096 like the servos.
Why the hell this did not happen in the shop and waited to show me on the flight line is beyond me other than thinking the hot weather has something to do with it.
What I am going to do is put my Turnigy i10 in this plane. With the i10 you can set servo frequency to better match the 4096 resolution. I know the Futaba 14SG is capable of 4096 but the 6014 receivers are not and the i10 receiver is.
Will follow up once I get the radio swapped.
