Notorious B.E.N.
I began making some tabs for the back side of the lower cowl. Each was measured to be 3/4" by 1". I used scroll saw to cut it out. I don't know how old this is because I got it from my grandfather so probably mid-60's. Still works great though!
After I had the tabs cut, I mixed up some 30 minute Epoxy with milled fiberglass and began gluing them on. I used some of the small and cheap clamps from Harbor Freight to hold the tabs in place. For the two at the front, there was a small gap so I used a syringe and needle filled with the remaining epoxy mix to shoot it in the space between and to make a filet on the sides. This was to help keep it in place but primarily to help prevent crushing the fiberglass.
![20150522_195941.jpg](https://lh6.googleusercontent.com/-FpB4oPfRa4M/VV_fPm2FmVI/AAAAAAAAB5g/-RCs4Yld5Cs/w905-h509-no/20150522_195941.jpg)
![20150522_200511.jpg](https://lh6.googleusercontent.com/-Blrb_RR1eZA/VV_fP8dRgsI/AAAAAAAAB5g/aBc65kmTbfc/w905-h509-no/20150522_200511.jpg)
![20150522_203207.jpg](https://lh6.googleusercontent.com/-ULl9U_h9hvs/VV_fP7KHHVI/AAAAAAAAB5g/eQ4DC7cFv64/w905-h509-no/20150522_203207.jpg)
![20150522_203221.jpg](https://lh4.googleusercontent.com/-3nAqvmkIDzQ/VV_fS22gKzI/AAAAAAAAB5g/QxWsBimccXI/w905-h509-no/20150522_203221.jpg)
![20150522_203250.jpg](https://lh4.googleusercontent.com/-oU4QsSr7uRM/VV_fTZA2zqI/AAAAAAAAB5g/jk8j6EdBcbs/w905-h509-no/20150522_203250.jpg)
