Reply sent.Sent you a reply PM
Thanks Kelly. I appreciate your input. I will "strongly" suggest the foot print and the prop bolt pattern remain the same as the DA, DLE, EME and like. This to me is a very tremendous advantage to many pilots that want to experiment. My hope is that enough sales from the 62 and the 124 can be generated to warrant Frank taking on this endeavor. We have considered a "pre-order" program. But that is going to be hugely affected on interest.So if the 75cc twin will fit in cowls with at least 11.5" width's then I would opt for the 75cc if the engine weight is about 4 pounds +or-. I don't mind if the plugs are angled down or strait. It needs to share the same prop bolt spacing and mounting foot print of the DA and EME 70's.
If it turns out it can swing a 26x8 or 26x9 the pleasure will be fine!![]()
Same here, looking forward to testing the BE62. I'm pulling the 3rd eme55 off the Edge,an bolting the 62 on her, at just over 16lbs she should be just a tad over powered, just how I like em.Looking forward to the 124 at me door! Thanks Rob! My old.....I mean sold.....104 will live again!
There is a vid out there with EF 104 powered by 124,an I must say impressive it is, I'd go as far as to say BADAZZ. I haven't seen much on the 62, found couple with 87" extra,an it looked like it pulled it well.From what I seen so far right on par with the other "over powered engines". Saw an EF 104 get thrown around with the 124 on SM and I was impressed. Saw the 62 and it too looks impressive. Success with your Edge Donnie.
