3D Cbarnes 3D Slab Thread
BalsaDust
I guess another question is what type of batteries do you want to use on it. 4S setup or 6S setup. Going 6S will be easy just running a couple of 3S lipos in series.
BalsaDust
Ok I got a couple options for you as soon as I get to a computer instead of my phone I will post up some links. Do you like stupid ballistic power?
BalsaDust
OK so here we go.
6S setup
motor
http://www.hobbyking.com/hobbyking/...SK3_4250_500kv_Brushless_Outrunner_Motor.html
ESC
This esc will work for the 4S or 6S setup. Its a little pricey buts its nice because you can crank the voltage up to the BEC. Most only put 5 volts out and its nice to get it up to 6V for the servos but can go up to 8.4volt if your servos can take it.
http://www.hobbyking.com/hobbyking/...Platinum_100A_V3_Brushless_ESC_w_10A_BEC.html
Battery
The 6S pack you have will work but its a bit large and all that weight hanging off one side will make it KE different in both directions. I would drop back to either a pair of 3S 3300's in series or save some weight and drop back to like a pair of 2800-3000 mah 3S packs.
Prop Start with like a 13x6 and work from their but prop it to pull around 60/65 amps.
4S setup
Motor
http://www.valuehobby.com/power-systems/brushless-motors/outrunner-airplane/gforce-g32-800kv.html
Use the same ESC as listed above.
Battery
Use a 4S 3700-4000mah pack.
Prop
Start with like a 14x7 but you will want to prop it to pull around 80/90 amps. I know the specs on the motor only say 12x6 on 4S and max load of 50amps. Those are CJ numbers. If you plan to stay WOT the whole time it will cook the motor and we will need to figure out something else but if your like me and most the time the throttle will be 1/2 or less and only using WOT in short burst then you will be fine
BalsaDust
Landed one in a tree the other day.
