I believe that they have them in a 90mm, 63mm, and a DIY kit so you can cut them to length. I'm pretty sure I have the 90mm on the laser but will have to double check. I've heard the 63mm are good for EF Extra. If you are going to run pro flow canister on this you'll need a 28mm to 30mm Teflon adapter, 34mm clamp, and a 28mm clamp. I got all these from DA.
