Before setting the incidence, I will be doing a modification, and some prep work, to the stabs/tail of the fuselage.
I have obtained this 9/32 aluminum tube, this is the OD, and the ID is 1/4"
I then mark a point, 25 cm from the trailing edge of the fuselage forward and 1" down,, from the top surface of the fuselage...
I then use a small drill bit, like 1/16", and slowly, make this pilot hole bigger (not shown), until I eventually drill from one side to another using a 1/4" drill bill.
once this is done, then I opened the hole with a 9/32" bit, and then passed the aluminum tube all the way across..
I then realized, this hole is not thru and thru parallel to the stab tube, so i made the hole bigger, and then glued them in with donuts and also used a long 1/4" rod, thru the tube, to check that it was parallel in both planes.
this morning, I will sand the tubes flush with the fuselage sides, and then this afternoon, I can set the incidence.
