Hi Rusty,
how ya doing?
I have ordered the servo mounting washers that are carbon fiber. Once they arrive, I will install them on all of them. Just put those on for now.
The servo arms are from AirWild Hobbies. They are double truss arms, and there is a UNI-Hub. You can rotate the hub, 90 degrees at a time, so that you can get the splines lined up with the arm, so that at center, the arm is as close to center as possible!! Big plus. then if need be, can use transmitter trim to get it centered.
regarding my geometry, I like to set it up at 1 to 1, or, if greater than one to one, the greater distance is that from hinge line to hole on the horn, as opposed to center out put shaft to hole on arm distance.
SO, I am using the hole that is 1.5" out, and the distance from the hinge line to the hole that i chose is like 1.7" out. I did not want to use the 1st hole, even though closer to 1 to 1, i will lose travel, which I will not need, since this will be strictly for IMAC.
but, by decreasing the travel, I am increasing the resolution. SO when i use my transmitter to trim to fly level, it will be smaller steps. Even though, i can also do this with my transmitter, to make the trim steps real small.
you are correct, one of them, i used 1.5" arms, so it is on the 2nd hole. the other set of stabs, the servo arm is 1.25", so I am using the first hole on the control horn.
this is the specs on the JR NXB 8921 servos:
- Torque: 363 (4.8V)/456 (6.0V)/562 (7.4V)
- Speed: 0.19 (4.8V)/0.14 (6.0V)/0.13 (7.4V)
- Dimensions (L/W/H): 1.55x0.82x1.59 in
- Weight: 2.96 oz
- Input Voltage: 4.8-8.5v
- MPU: 32 Bit
- Shaft Support: Dual Ball Bearing
- Comparable to DS8911HV and NX8921
have no idea what the torque would be at 8.0 volts.!!
