Can explain more on the Airwild adjustable servo arms that can be adjusted to zero. Looked them up but could only find arms that fit a Seiko servo and nothing on. YouTube.
http://airwildpilotshop.com/MoreInfo-1.asp?title=product&id=288
So when you tighten the four hub bolts there must be some play so you can adjust the centering of the arms
Nope, not like that, there should be no play between the 4 holes and screws with the half arms.
Did you rebalance your propellor to help minimize the vibration of that 150 you discussed about !
YEs, amazing difference.
Looks great Cam , hope you get many flights between those two Carden Aircraft .![]()
exactly Rusty!!!These hubs get the perfect sweet spot between the spline so the arm is 90 degrees to the servo.
If the servo has 23 spline that means there is 15.6 degrees of each spline on the servo which makes these hubs very desirable to centre the arms![]()
exactly Rusty!!!
this is why I like them, and both servos are at ZERO sub trim.
what ever that means!!!
Hello everyone, I will try to give it my best shot in explaining these air wild unihubs.
this is one wing, and two servos will be ganged up on this one side.
I want to attempt to make the best mechanical set up 1st, so that both servos are perpendicular to the servo arms, and form right angle, and then the control horn hole is same distant to hinge line on both, the inboard and the outboard horn.
I also want to make the sub trim on both servos to be zero, although I understand the JR servos are the least linear with regards to movement towards the end point.
View attachment 93588 View attachment 93589
in order to achieve this, the beauty of the air wild Uni Hubs, is, that the hub can be rotated up to 4 times, to get the most perpendicular position of the arm on the servo output shaft.
this is the hub..
i only positioned one of the two half arms on there
I will mark it
I have this servo, and I connected it to a servo tester, and place it so that the output shaft is in middle position. I marked both the hub and the arm
rotate 90 degrees, definitely off...
rotate another 90 degrees, still off
rotate another 90 degrees, I think this one is good...what say you??
