3DeltaFly
I've just put 5 flights on mine and I'm loving it. Can't add much to your flight report as it would just be a carbon copy. The 70 EXP is very stable at all speeds and tracks like she's on rails. No mixes needed as there is insignificant to zero KE coupling (CG on mine is set very close to neutral). The AUW came in a bit heavier (4.98 kg or 10.98 lb) but then it is a 10S setup:
Hacker A60-7S V2
Xoar 20x10 PJN
Phoenix ICE2 HV80
CC BEC PRO
Pair of 10S wired 5S 4000mAH Skylipo packs
3x 7985, 2x 5245 Hitecs
Flight times of 7:30 minutes pull the packs down to 3.86 volts per cell. That's with a 50/50 mix of precision and 3D. After the initial charge is bled off the packs (2000 watts peak) the power remains a steady 1900 watts with the 20x10 PJN.
Did some run-up testing with a Xoar 21x10 PJN and measured 2300 watts. That should add another pound or two of thrust. Can't wait to try the new prop, which should make hover pull-out a bit more energetic.
Hacker A60-7S V2
Xoar 20x10 PJN
Phoenix ICE2 HV80
CC BEC PRO
