I'll have to verify the length tonight. Sounds like the 4" ones may need some trimming from what Enterprise posted.
70mm is the ideal length if the servos are in the rear position, so presumably whatever the difference in the output shaft location is when turned forward vs. backward is the amount to add to the 70mm length. I think that is only about 10-15mm or so. 80mm would be 3.15 inches, so probably a 3.25" or 3.5" would work well also.
To get the right length for sure though, try mounting a servo one way and marking the location of the output shaft, then flipping it around, and marking. Then measure the distance between the two marks. 70mm is a great length for the rear position, 75mm would work too.
Edit: I found a website with the dimensions for an HS-7955 on it:
http://www.goldenskiesrc.com/HS-7955TG.html
and it looks like the difference would be .81 inches, or about 20mm. So if I was going to order a new turnbuckle a 90-95mm one would be perfect. Or about 3.5 inches.
I ordered up some 90mm turnbuckles
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Definitely a safer option, and for the 12 bucks it cost to make a second order, why not.
