Hey guys, I am finally working again on the mxs, I know there was some mislabeling that took place. I have one bag that says Main Wheel, I have to assume that means Main Wing. And one that says Stab. This has to be for the elevator.
Do I need to be aware of a problem? Is it the turnbuckles for the elevator are in the, "Main Wheel" bag and the turnbuckles for the ailerons are in the stab bag.
I also remember reading the elevator servo should face rearward, and the arms should be on top, but I need to use 90mm turnbuckles, then use the intended stab turnbuckles on the ailerons.
Also I remember easing there is an extra set of horns, and I should use the long ones on the stab.
A quick clarification would be extremely helpful so I can move forward without any frustration or delays. Thanks. AKF
