The more I watch your video and weigh the advantages vs. the possible weak links of our current systems, the more I am considering this system for my project next year.
Is there any risk of degradation of signal possible with longer fiber optic cables? As in roughly 120 inches.
With a three or four aileron servo setup, would the encoders and decoders be singular in design? Or would they be incorporated within one another? As in, a single board of one or a single board of "x" amount required?
With removable stabs and wing panels, how is the system designed to facilitate quick plug in access? (Forgive this question if you've previously answered it)
With a 15-17 servo system, what size battery, i.e....mah rating would be necessary for the encoders/decoders required?
And finally, what would a forecast of projected cost for such a system be?
To your first question, as far as degradation of the light source, no your looking at a possible 120 inches , and these will not degrade for at least 100 feet.
Also for a peace of mind, I have tested the FO cable by pinching it tight without loss of signal, (not recommended) but they will still work.
If you use one channel per servo, lets say for both ailerons, meaning 6 servos , you would need 6 channels , in turn 6 encoders and 6 decoders. Unless you are using Y connectors , which I doubt you would .
From the RX, these are 6 individual units, but it can be as a single board with 6 encoders as you have seen in the 9 channel single board , the number is not important.
For the decoders, it would be impractical to have them bunched up in two 3 units for each wing, but it can be done.
Good question, for the wings, the encoders can remain in the wing root cavity if one desires , and simply have an extension from the RX to the wing plug in. plus the power wires, Here for 3 servos, one larger wire to feed back into the wing and seperate into 3 for the 3 decoders.
For the Stab since they are further from the RX , we have fiber optic inline connectors for this and of course you need connectors for the power.
First you need a battery for the RX which also powers the encoders . At 17 servo encoders @ roughly 20 ma ea. plus the RX at roughly 20 ma, that gives a total of 360 ma. and for this I would use about 1000 ma Lipo or which ever chemical battery you are using. You can go bigger here if you wish, Remember there are no servos plugged in this part.
For the servos/decoders, use whatever battery you had intentions on using in the first place, the decoders takes less power then the encoders , so less then 15 ma each.
For projected cost I will contact you privately since we are not allowed to talk money in an open forum.
