SleepyC;1825 wrote: I'd get Gorilla glue use a seringe to put the glue down into the crack, (don't over do it) tape down the crack and let it expand and cure.
Again, using a minimal amount will be key. But if you do it right It should be as strong as new. I'd also wet the foam with water first so the glue really works!
