rcdude07
I bought all electronics from Heads Up RC 2 weeks ago. Using two HURC 22A ESCs and two Emax CF2812 1600kv brushless motors with GWS 7035x3 props (one normal, one counter rotating). This was a recommended power setup I found for 3S lipos online from one YouTube video and one post from someone who contacted HURC years ago for a power recommendation. I bought the props from some dealer on Amazon with Amazon credit we had.
Monday morning I was up about an hour before the alarm goes off, so I went to the hobby room and started the build. I cut out foam from the battery compartment to make room for a 3S pack, widened the hole to the wing saddle to allow for battery to ESC leads, and then looked at the plan of how I'm going to cut the nose for magnets to allow easy access to the battery compartment.
Decided on cutting the top half of the nose off to create a battery bay. Cut the halves off this morning and then cut the elevator and rudder push rod tubes to size, as well as sanded off the rough bumps from the molding on the outside of the fuse halves this morning. I need to clean up my cut lines (later after the fuse is glued together). I need to check my magnet stock and see if I have enough for 4 pairs of magnets for the battery hatch.
