acerc
Yep, fantastic run right up to being a nightmare... lolWhere is the DO NOT LIKE Button??!!!
Really sorry to hear about your flying day. Sounded like it was awesome right up to that point...
I got a few minutes to pull some covering on the fuse, the front of the fuse is bad but the rest is ok enough. I found on AJ's site that they have replacement front ends, they call it the motor box. The other damages were the cowl, pants, and gear cuffs. I order all that stuff from AJ and will get the covering locally when the time comes. The right wing took minor damage, the left wing is more severe but very repairable. Altogether the rebuild will come in under $300 which is far better than a new airframe at $1200. The hardest part is going to be be getting the covering back the same as it will all have to line up with the rudder and cowl. Speaking of cowl, I already have the replacement as I bought a spare with the airframe for when the Valach came out. And this is a good time to swap the engine out being as it is getting all new wood. The GP123 should do quite well in this airframe.
