jeti DS 16 thread
thank you Rich. You are going to love your new Jeti transmitter.
Some advice, once you get it, be sure to make sure that it is updated.
Also, whenever you buy receivers, you will want to make sure they are updated as well. Be sure to order the USB connector, so you can connect your Jeti Tx and receivers to your PC and do updates, etc...
Quick question for the Jeti CB 200 users out there.
I have three receivers.
two for the radio, and one for the switch.
On my radio receivers, I am conscious to place them away from each other, and I make mounts for them, so that the two leads are at 90 degrees to each other.
IS this necessary on the switch receiver?
poprlite
Will the tx program the sensors or is the profi box needed. Just can't figure out how some of this stuff works.
For the most part the the transmitter simply discovers the sensors that are installed and displays the information they provide. Some sensors need to be configured and this is where the Jetibox becomes useful.
No need for a profi box..
Wayne
