IMAC new to me dalton 260/300, just want to fly it!!!
cbarnes0061;13091 wrote: Exhaust and tank look great.
thank you!!
i am going to install the Rx and the throttle servo. i do not like the control horns on this airplane. some of them are loose. i know that the post type horns, on this airframe, are thru a hard point on the surface. if this is wide enough, i will try to install the aeroworks aluminum horns that would allow me to use 6 screws to fix them, and then i can use 2 ball links per turnbuckle. it will be a more solid construct.
It is great seeing this old bird getting a new lease on life after all those years wasting away in a storage shed. Great job Doc!
pawnshopmike;13161 wrote: It is great seeing this old bird getting a new lease on life after all those years wasting away in a storage shed. Great job Doc!
i just hope it does not disintegrate once it gets airborne!!!
i think i can find a picture of the last time this airplane flew.....
give me a minute.
wow, i found this airplane's build thread. it was started 2005 and it was completed in January 2006. so that makes the airplane about 8 years old. last time this airplane was in the air was in 2008. that makes it 6 years in Storage!!! Ouch!!! pray for me!!!
these pictures are from back in 2008
i have removed the post horns from the stabs/elevators and installed these Aeroworks control horns, which are just awesome!! except the screws that come with it, which plain old suck and are poor quality. i ended up using the screws from the RTL fasteners sets. these screws have incredible purchase, and probably the reason why the aeroworks screws stripped in the heads. i also like how these will be more to the center of the hinge line compared to the post horns that were on there before.
canister is installed. i opened up the bottom of the fuselage some more. i will install one air dam as well to help extract the hot air out. the throttle servo is installed as well.
getting close now. all i have to do now is install the radio system and install the servos to the surfaces!!!
i also have over wrapped the headers with the mcmaster carr teflon tape, and then covered it more with the standard teflon tape from Lowes.
Keeps the leaks inside the header.
My flexy headers leaked from the first start up, so I found some high temp tape and installed 3 wraps around the flex section. So far so good.
