There are also people who choose to use 1" arms because they only fly a certain way, 1.5" on wings because it's typical, some use 1.75 on wings, and on the tail feathers anything from 1.5 to 2 is typical depending on flying style.
Yeah, that changes things a bit from my old thinking. Back before I took a break for 8 years, the servo arms were really all between 1 and 1-1/2" long. So, I could generally work with a manufacturer's hardpoint location, most of the time. Now, with a lot of planes being factory setup for more throw (and add to that servos that have less travel for the manufacturer to gain more resolution... I'm still trying to figure that one out, because less travel by definition means less resolution, haha) it's common to see 2" arms (we would have found that crazy 8 years ago, haha). IMAC guys should still be using 1" arms on their elevators, even 3/4" for max resolution, so there is no longer one ideal spot for the control horn. I used to say 1/8" off the servo body, but that is not the case for 1-3/4" to 2" arms. I started spacing AW metal control horns wide enough for conicals on each side of the ball joint and that's definitely the way all these fiberglass horned planes should come stock, because of these longer servo arms, definitely.
For this reason, many times I will CNC cut my own custom horns.
Can you move in next door to me here in Costa Mesa?
I love your build threads, btw.
You will continue to find the Pilot planes are well built but ... has the horns in the wrong location.
Correct. And, the hardpoint is too small for me to work with for moving it. So it's either compromise, new hardpoint, or mount to the side of the control horn instead of the middle. I mounted to the side of the control horn on my H9 Sukhoi and it worked great. What's funny is the Pilot is even further from ideal which made it basically perfect for a side mount. My pivot point is exactly where I want it on this Pilot Extra.
