Matt Goethe
Gyro - have you flown this plane much? Just wondering how it flies precision aerobatics and 3D.
Have you flown your extra any more since the upthrust mod?? I'm curious of your results as I'm following a thread on rcgroups that talks about it as well.
Did you confirm that your plane did not have upthrust installed? Tim thought it was only an issue with <#100, however I checked mine and it appears to have zero upthrust. I have #106 and I beleive you have #105.
Thanks!
View attachment 30014View attachment 30015
@gyro, I have a question on your redwing extra. In the build you mentioned you had to add "up" thrust by adding washers to the engine and cowl to match. I am looking at my cowl and how it bolts on that only way that would work to change cowl position is the top bolts. Therefore you actually have it Down thrust. Am I correct in this?
