While the epoxy cured for horns, I started on the engine install. The motor box has a DLE 30 template printed on it, but after my measurements I found it to be slightly off, I believe its was low about a 1/8" or little more, which is not that big of a deal.
Once installed, the engine needed just a little more standoff length, so I small thick washer did the trick.
When installing the engine cowl, found one of the cowl blind nuts had no threads....
....good thing I had one, so popped it out and glued in a new one.
Once installed, I thought the motor box was not square after seeing this uneven gap. Found its actually the shape of the cowl.
You can see the center engine hole is slanted compared to the outer air holes. No fixing this.
