ready to be hotwired
Thanks! Interesting. I see there are quite a few options. 12-15V with wattage being the largest difference. What should I be looking for in Wattage. Seems like 300w is commonly used for lights, but they go from about 10-900w from what I can find.I use a low voltage lighting transformer for my bow now, 14 VAC, in the past I used my car battery. Both work fine.
I cant remember if you've talked about your hot wire setup or not? I have a 3.5ft hot wire I acquired from a friend that passed away and all it has is two alligator clips and a ground. No idea what power source to use. I've been following your build here and I don't recall you talking abut the hot wire setup you use for this. Thanks!
Also, what size NiChrome or equivalent wire size to you use for the pink foam?
