Servos Locked Up
Bushwacker
3DRCF Moderator
Thats a good idea Mike. What about a power box or something like that? Something I can plug everything into and will give me clean regulated power to all servos plus the RX, is there something like that out there?
Xpress
Or since you're using 5245's, just use a 6.6v LiFe battery to your receiver. I probably wouldn't rely on an integrated BEC in an airplane that size anyways..
Bushwacker
3DRCF Moderator
Why is that Xpress. You don't trust them bud? I kind of agree with you. I have never had an issue with an integrated BEC before, but since this issue with Airboss which is supposed to be bullet proof has happen I am a bit apprehensive now. Im not really a fan of adding more batteries for the BEC to run servos, just adds more weight. On my Heli's I just tie the BEC into the main power and use a scorpion backup guard. That has always been a solid and reliable setup for me for years and I really don't notice any drop in flight times.
Xpress
It's just another option, plus a small LiFe battery won't weigh much. You could also use like a Castle 10 amp BEC to power the servos. Just removes the additional load from the ESC and gives you a lot more power for the servos.
cam4569
[MENTION=3728]Bushwacker[/MENTION] whats the update on your situation? I have read some good ideas/advice so far, any results? the plane flying yet?
Xpress
Looks like they might've showed up on Friday, I didn't get to them until yesterday though, but they're checked into the repair queue and awaiting a technicians skilled hands :)
