i have some practically new 7245's and I noticed some slop in the gears. I inspected the gears and they looked good so I changed them anyways. I put the case back on and same slop. I had a 5245 case I tried on them no slop. So I guess the top case pin holes has already wore out. crazy. This and some troubles with some 65mgs has me worried.
sounds like you're joining the 10%ers.... you know, the ones who can actually abuse a servo to it's breaking point by just going out and flying!
dth7
Just trashed a savox 0255 in my MXS tonight! An aileron locked up at about 30 degrees deflection. It was an interesting minute getting it back on the ground! It was after a nice crankshaft. Oops!
wedoitall
Member
thats pretty much why i put a 5245 in the elevator of my 51 slick and 48 mxs. seems like im really hard on elevator and rudder servos. i wouldnt worry as much if my daily flying spot wasnt as wooded as it is. if i had more open field.
does anybody know the turn around when you send servos to hitec? atm i have 4 65's 2 85's 1 5245 and the 4 7245's i would like to send off. i have a set of 5245's i could use but i hate to.
About two weeks
also how does the servo programmer work? can you program a digi to react in a certain failure a certain way?
Sort of. You can program the servo to reduce power during a "binding" so that it won't burn up the motor or circuits.
