ryan_m
I have heard it said by many that the ideal setup is to have your servo travel in the 130-140% range in each direction. Usually servos stop moving somewhere around the 140-150% range, so this gets them moving as much as they can move without trying to move past the point that they stop. That said, if the servo stops at say 138%, don't set your tx past that point, in fact come back down a few % to make sure you aren't trying to overdrive it.
Like 3dNater said, you want the travel as high as possible to maximize resolution, so you don't want a super long arm that makes your travel be only 90%, use a shorter arm, get that travel up in the 130-140% range and you will be set.
And on that Yak, HS-65's will be a dramatic improvement over HS-55's! Do it.
