Went flying today, it was hot and humid with nearly no wind which made for good flying and lots of sweating.
A new quality control problem cropped up on the Hangar 9 Extra. On my second flight the airplane started making an odd whirring noise when going fast and then dropping to an idle. I decided to land to check it out and when I came in to land it was idling way higher than when I took off. I went around and dropped the trim a few clicks and it was still idling fast, but landed fine. Tony said the engine seemed to be moving more than normal so I pulled the top of the cowl off to look.
I think this explains the noise, but even though the engine moves because the firewall flexes, I don't think it's moving enough to cause the idle issue, but maybe it is. I'll find out more when I can get it in the shop and pull it apart.
